Delaminated in Seattle
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=50043
Author:  Pmaj7 [ Sat Dec 09, 2017 11:26 pm ]
Post subject:  Delaminated in Seattle
This is Gurian purfling attached with CA. The ca held fine! I suspect I got it too hot. I was bending at 300, but it briefly hit 380 (the blanket anyway)
Am I right in thinking it was the Heat?
Also, I did use tape. However only three places and I did not tape the middle of the waist or the top of the upper bout, the two places where it delaminated.
I'm thinking I will still be able to use them if I just get them locked in there nice and tight. Thoughts?
Author:  Terence Kennedy [ Sun Dec 10, 2017 12:05 am ]
Post subject:  Re: Delaminated in Seattle
I had some bwb from LMI delaminate just with bending it for insertion so I bought from Gurian. No problem with some but others delaminated the same way.
I called Gurian and it turned out I ordered seconds. There is a code in the product description that identifies them as seconds and they are cheaper.
They replaced them with top quality and I have had no problems. Might want to look at the product code and give them a call.
As far as bending I tape the binding together with only small gaps between the pieces of tape and have had no issues. I go to 300. I think more tape would definitely help.
Author:  Barry Daniels [ Sun Dec 10, 2017 10:41 am ]
The purling in the second photo can probably be reattached, but that first one with multiple buckling is toast.
Author:  meddlingfool [ Sun Dec 10, 2017 1:13 pm ]
Well, binding can be a real,drag with a delaminated purflings. 380 is too much heat IMO.
I would spritz the buckled bits with water and try to flatten with the clothes iron. It's amazing what that can do to restore order.
